lower door seal where to buy
Huntingmark
Kansas City
Where do you recommend I buy the lower door seals for my 2004 Dodge Ram 1500? I cannot find seals for this range of model years.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
all the mail order places
order through
Steele Rubber
They also go to all the big Auto Shows & Swap Meets
HemiLonestar
MD
There was a TSB for these years back, it upgraded part numbers. Think I threw it away after I bought mine lol.
Edit: my OCD from the service for maintenance tracking has apparently quite spilled over into my personal life lol. @Huntingmark here ya go:
TSB 23-049-05
Drip Rail Door Seal Torn
Date: October 12, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-008-04, DATED
MARCH 2 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. REVISIONS
INCLUDE THE ADDITION OF 2005 MODEL YEAR AND REVISED PARTS.
Models: 2004 - 2005 (DR/DH) Ram Truck
Overview:
This bulletin involves replacing the secondary door seal with an improved seal.
Symptom/Condition:
The drip rail or secondary door seal may become torn from contact with the lower “A” pillar of
the front door.
Diagnosis:
Inspect the secondary door seal. If the seal is torn, perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 55277188AB Secondary Door Seal - Standard Cab -Right
1 55277189AB Secondary Door Seal - Standard Cab - Left
1 55277190AB Secondary Door Seal - Quad Cab - Right
1 55277191AB Secondary Door Seal - Quad Cab - Left
Repair Procedure:
1. Remove the secondary seal from the retainer (Fig. 1).
2. Install the new seal using the appropriate seal listed in the Parts Required section
above.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
23-51-08-95 Install Secondary Seal, Both Doors 0.2 Hrs.
Failure Code:
ZZ Service Action
