Where is the IAC on 1500, 4.7 2008 ?
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
You don't have one. It would be on the driver side of the TB if you had a mechanical TB. You have a newer drive by wire setup.
HemiLonestar
Navy Badge Coast Guard
MD
Like the hemi TB, it's integrated into the electronics.
D
davidoc080808
I cleaned throttle body valve and it greatly improved idle running, but will still shut off slowely after about a minute or 2 vs right away when not giving it gas. If i cant replace the IAC valve, what do i do now? Should i swap the map sensor?
