Winding noise coming from engine and and belt squeaks when I start.
02ramboi
live oak florida
4.7 v8
I'm not sure if this is the right section for his but I'm still new to this site and still getting the hang of it. I cleaned my engine with degreaser and after that belt start to squeak. I sprayed belt lube but didn't seem to help. Could it be one of my pulleys. Any help appreciated thanks btw it's a 4.7 v8
Tteal235
If you still have the stock plastic pulleys that could be the issue. Or the fan belt could be going bad. Before I replaced mine with the metal ones, one of my plastic pulleys started making that noise or the belt did idk but the pulley blew off and wrapped the belt around the fan.
All I did was replace the plastic for metal pulleys and got a new fan belt, problem solved. Every now and again though the noise could be due to cold weather on start up.
Hope this helps
02ramboi
02ramboi
live oak florida
4.7 v8
Hope this helps
Looks like the belt was changed right before I bought the truck but not the pulleys.i will definitely be changing them out thanks.
lharrell79
Did it only start to make noise after you decreased the engine? It might just need to dry out. How long has it been making noise?
02ramboi
02ramboi
live oak florida
4.7 v8
After I cleaned it but it has been sitting a while and it seems to get worst as it sits
lharrell79
Do the pulleys and belts maybe have degreaser coating them, causing them to slip? It's odd that it wasn't making noise before, and now after degreasing it is. That would lead me to believe that it's the degreaser.
Litenyaup
Idler pulley. Mine did the same thing
02ramboi
02ramboi
live oak florida
4.7 v8
I washed off all the degreaser and I didn't spray it directly on the belt and the pulleys but I'm guess some may have gotten on it somehow in the wash off process
Fatboy1989
