Wolfbox Retractable Bed Step. Easy Step for Your Truck Bed.
Wolfbox
Supporting Vendor
CA
Looking for a rock-solid bed access solution for your Ram? The Wolfbox Retractable Bed Step is precision-engineered to fit the 2019-2026 Ram 2500/3500. Whether you're reaching for tools or organizing heavy payload, our step eliminates the struggle, providing a stable, low-profile entry point to your rig.
Key Features & Highlights:
  • Instant Kick-Down Access: Forget complex electronics. A simple nudge with your boot engages the heavy-duty spring mechanism for instant deployment—reliable even in the muddiest job site conditions.
  • Ram-Hardened Construction: Built from high-strength, die-cast aluminum alloy to support up to 330 lbs. It’s rock-solid, corrosion-resistant, and ready for a lifetime of daily abuse.
  • No-Drill Precision Fit: We’ve custom-designed the brackets to match Ram factory mounting points perfectly. Enjoy a hassle-free, 30-minute bolt-on installation with no permanent modifications.
  • Stealth Performance: Retracts flush against the bumper to maintain your Ram’s bold aesthetics and maximum ground clearance for off-road durability.
  • All-Weather Stability: Features a wide, slip-resistant stepping surface and a rugged black powder coat to resist rust, chemicals, and road salt.
Perfect for: Professional tradesmen, outdoor adventurers, and Ram HD enthusiasts. Work smarter and save your knees—upgrade your Ram with Wolfbox today.
Click here to purchase!
