Burned out turn signal warning.
dalec2404
Illinois
I own a 2013 Ram 1500 sport model. For about three weeks my left rear LED turn signal warning light has been coming on at start up and the left turn indicator fast blinks. This has happened before on the right rear LED turn signal and replacing the turn signal assembly took care of it.
In this case I replaced the turn signal assembly assuming this would correct the problem but it has not. The warning light still activates on start up and the left turn indicator fast blinks. All light assemblies front and back (turn lights, side markers, brake lights etc) work properly. The only assembly showing problem is the turn signal/puddle light on the driver side outside mirror. All LEDs are lit but it fast blinks.
Has anyone else experienced a problem like this or can offer some suggestions?
Papa Red
Papa Red
Nebo, NC.
Welcome to the forum.
Post your question in the 4th generation section and you will get some help.
Red
