RonJon '06
- Jan 2, 2014
- 3,372
- 1,183
- Southern Minnesota
- 2014, 1985
- 6.7, 360
The driver's side vent window seal on my 1985 W350 was leaking so when I decided to replace it I took some pics and notes. This should be the same procedure for any Dodge Ram truck or Ramcharger 1981-1993.
You will need:
A pair of Vent window seals Part #vwk 3110 78
Phillips screwdriver
Torx bit driver #25
Flat head screwdriver
7/16" socket
First thing is to remove the door panel, its held on with 3 screws, one torx screw on the window crank and one 7/16" bolt on the door handle.
"][/URL]
"][/URL]
Pry the panel off.
"][/URL]
Remove the window glide seals, the lower two are held in place with metal clips.
"][/URL]
"][/URL]
The vent widow assembly is held in place on the top with a screw on the upper outside of the door frame and on the bottom by a bolt. There is an access hole for the lower bolt above the cutout for the speaker.
"][/URL]
"][/URL]
Once the fasteners are removed tilt the assembly back and up to remove it from the door frame.
"][/URL]
Now that the assembly is out remove the old seal and vent glass from the frame.
"][/URL]
"][/URL]
Insert the new seal and then do everything else in reverse order.
"][/URL]
"][/URL]
The seals cost about $50 for the pair and it took about an hour for one side. There's also a good video at 1A Auto.
You will need:
Torx bit driver #25
7/16" socket
"][/URL]
"][/URL]
Pry the panel off.
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
"][/URL]
