I’ve been having issues with wet/damp carpet on the driver side floor. I’ve got Husky floor mats and when I remove them the carpet underneath is damp to the touch. Tried a water check but couldn’t pin point where the leak was coming from. Took it into the dealer's hip today because I also had the center tail light leaking as well. The dealer called and advised that the center tail light was covered under the extend warranty. However the door leakage was coming from the seals, and not covered by warranty. Both the driver door seal and the frame seal needs replacing . That would run $400.00 …… and it would be three weeks to get the seals.
Anyone here have experience with the door seals leaking, and if so, how did you fix it.
