2003 1500 4x4 Shocks for towing?
pajeepman
SE PA
5.9 magnum
Have a 2003 1500 quad cab hort bed laramie 5.9. I need new shocks for the rear, I will be towing a 17' single axle camper with a max GVW of 3250 on the camper.
Wondering what you would suggest, I am leaning towards Monroe 911187 reflex shocks or Monroe 58640 sensa trac load adjusting with the coil over spring.
I do not do much towing or hauling, just the camper and occasion load of fire wood. Because of this i do not want something that gives a harsh ride.
I am leaning towards monroe because of past experience and price as they have a good rebate right now. Thanks
Sent from my SM-J320P using Tapatalk
reindeerman
Knoxville, TN
2011 & 2002
I used the Monroe reflex on my 2002. I towed a livestock trailer weighing about 5,000lbs. The weight distribution hitch kept the truck form sagging so I didn't need the coil overs. Had them on the truck for 1000,000 miles before I sold it.
pajeepman
pajeepman
SE PA
5.9 magnum
I ended up getting the sensatracs with the coilovers. I will report back later after i install them and drive with them for a bit.
pajeepman
pajeepman
SE PA
5.9 magnum
So far I am impressed with the shocks. I installed them tonight and put about 20 miles on it. Of course anything would be better as one shock was dead and broken into 2. Raised it about 1.25".
airdrianify99
Bilstein shocks are
Goodie1990
