Thread: Black in winter
View Single Post
Old 01-11-2017, 02:20 PM   #7 (permalink)
THETANK
Ram Year: 2015 R/T
Engine: 5.7L Hemi
Default
does not help your situation but I always store my toys for the winter. I told you I could not help you lol. Actually as long as you spray the underside at least once a week you should be fine, luckily were I live they do not use salt as it's to cold and salt would be a waste. Again even though salt is not used in my vicinity I take the car to an indoor facility and give the underside a good spray, if not busy I dry the car off and let the underside drip dry. The wash holds approximately 12 vehicles so if I go 1/2 hour before closing i's not busy and I can hand dry etc. Good luck fighting Mr Salt.
__________________
Sheep get nervous when I am around, is it because I have rubber boots and gloves on
Where the $$$$ went, 14 MagnaFlow exhaust, 5% tint back 20% side windows, tonneau, sprayed box liner, Belltech 2/4, Spohn pan hard Hellwig sways x2 K&N drop in
THETANK is offline   Reply With Quote
