airlift 1000
hemi_hawk
not sure if this belongs here, I was looking into these and a hbs 2" leveling kit and what I cannot figure out about this kit is can you adjust the air in the bags from inside the truck ? if so how ?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
On a good airlift kit it should come with a remote that always you to adjust it from inside the cab.
audio1der
Airdrie, Alberta
They sell optional compressor kits which allow you to inflate (turn on the compressor) or deflate (open a one-way valve) from inside the cab.
However unless you have a tool chest in the bed to install the compressor in, you're left to mount it under the truck. For many of us due to severe weather, salted roads etc that's not an option.
jlb
MT
CTD
I mounted my compressor in the engine bay. Installing my Volant CAI opened up some convenient mounting space where the stock intake used to sit.
rbrumm
North Central Iowa
Just ordered my airlift 1000's. Hope they are as easy to install as they make it sound.
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
very easy man, just make sure you drop the rear end to open the springs up
i wrapped the end of a pry bar with tape and used that to help put the bags in.
the hardest part was getting the airlines on the barbed ends other then that
1-1.5hr and a few beers later, no more sagging. good luck.
Power247
High Point, NC
6.4 HEMI
They really are that easy to put in. I used a12" piece of 1" dowel with the end rounded to help feed the bags through the coils.
Sent from my Nexus 7 using Tapatalk 2
h2oman
SoCal
Make sure you take all the load off the suspension. Get the tires in the air if you have to. Cake after that.
audio1der
Airdrie, Alberta
I put my bags on top of a heat register and cranked the heat for a while. They folded enough that it was super easy.
Power247
High Point, NC
6.4 HEMI
Nice tip. Wish I had thought of that...
rbrumm
North Central Iowa
Did yours come with two of the black spacer things per bag, and did you use both?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Mine only came with one black circle for each side.
$miley
audio1der
Airdrie, Alberta
^ that's a great idea.
I didn't have a jack capable of fully getting the springs unloaded, and despite my 80,000BTU heater nearby is was cold as f*ck in my garage; there is no way I would have thought of that. The floor register idea came to me on one of my many trips inside haha
