The tech hooked it up to a test jig at the shop. I have not measured the voltage myself. I got in with the rig Friday and was hit by Ebola-bird-SARS. I have been hold up inside all weekend.
Only 'emergency' test I did was to slam on the brakes at 20 MPH in the parking lot at LaMesa RV to test my load tie downs. Kingpin hit but didn't really make that much noise.
There could be a range of trucks with the issue. Mine does not currently have the issue.
But how does it do under emergency situations?
It was never said the brakes don't work with factory brake controller, they just don't work as well as people expect coming from older models with built in controllers or others who came from an aftermarket controller.
Have you seen the data BossHogg collected comparing older style integrated vs current? Or even vs a Prodigy controller?
Boss, could he be experiencing better braking performance from having more axles, and 7k axles. Maybe smaller brakes vs yours??
Yes, your truck has the "issue". It is Chrysler's design in the ITBM that is available in all 1500, 2500, and standard in most 3500 RAMs beginning in model year 2015 and continues with 2016 production.
Chrysler's design does not allow more than 70% of braking effort to be provided to the trailer at vehicle speeds under 30 MPH. The manual slider does not over-ride the 70% rule preventing proper setting of the gain. I don't think the ITBM provides 100% at speeds above 30 MPH but I can't provide that until spring.
70% equates to about 7 volts output (measured), depending on what your trailer's brakes require for a forceful stop determines if you will experience the ITBM braking design.
I have two Dexter 7K axles with 12x2 brakes at each wheel on my Montana. I need 10.5 volts to get forceful braking action, 7 volts provides a drag.
As painful as it may be you should review the entire thread to gain a full understanding of the issue and how it could relate to your equipment.
Now I understand, his truck did not have the goose-neck prep package and the dealer added the 7 pin to the bed.
I looked up his fiver and 7K axles come in an option package (Voltage Luxury Interior Package) which he didn't make mention of. I couldn't find data on the standard axles but it does come with three axles.
Are the 2014 ITBM affected as well?
Owning a Cummins power pickup always seemed out of reach for me, now that I have one, it seems that the good folks at Chrysler have messed up the dream.
No, the bump in the road is a prius you ran over because you couldn't stop your truck and trailer in time. Sorry I couldn't resist.Have you considered a low mile used cummins? The ITBM issue is on 2015+ trucks.
Could always go the way BossHogg and others have and install a Prodigy brake controller too.
Don't let this little issue stop you. It's just a bump in the road.
I've read the whole thread and subscribed, have a 2016 on the way. I don't see anyone confirming the same problem exists on 2016's. The part number has changed again for 2016.
Oh, and I looked into retrofitting a 2014 ITBM into a 2015 or 16, can't be done. One of the inputs is configured differently.
...does anyone know who makes the ITBM for Ram?
Here's an interesting read: TRAILER BRAKE SYSTEM HAVING TRAILER GAIN OPTIMIZATION - Continental Automotive Systems, Inc.
Be sure to look at the pdf file, it gives a nice flow diagram.
Has anyone confirmed that MY16 has the same problem? I mentioned earlier that the part # had changed again.
If the ITBM part number changed for 2016, then my dealer didn't look it up correctly. What is the new part number for the 2016 ITBM?
