Gravel
ptuttle78
Anyone know how much weight of gravel a 1500 truck can haul?
OzarksRam
SW MO
I don't know your answer but I though I would give you a heads up on the responses you will most likely get. I am in no way trying to be a smart ***.
#1 refer to your owners manual for maximum payload rating
#2 as much as you can fit.
I have done the second option in old Dakota when i was a teenager and would not suggest it. I bowed the front of the bed to where if was touching the cab and put a crack where the bed sides meet the bed floor. :)
mtofell
3/4 minus weighs around 3000# a yard so you'll likely be pushing limits or over them with a half yard.
Skerj
FL, from MI
Probably the same amount as it can haul in feathers...:favorites13:
Are you talking riding on bump stops, bending the frame, and blowing suspension components or what your truck says on the door jam sticker..?
P
ptuttle78
Yeah, I dusted off the owners manual and it says the payload is 1600 lbs
gustheram
Central Florida
5.7L
Don't forget that 1600 includes the weight of you (minus 150lbs I believe), any other people in the truck, and the weight of any random stuff you keep in the truck. Also, if you've added accessories such as side steps, bed cover, etc, take the weight of those off your payload. I don't know that the owner's manual is the best source of truth for your specific truck either as it lists best case scenario from what I recall. Consult the sticker on your door sill and see what that says for your specific truck. Depending on the state you're in, limits aren't a suggestion. A friend's husband's cousin is doing 5 years in prison for an accident that killed someone because his truck was overweight.
InvictusII
6.4L
Stick with half a yard.
This was a full yard+ in a 2500. It squatted about 2-3 inches.
dbrock34
This is with 2300 lbs of stone with the 1.75" spacer in the rear. I only had to drive a mile.
Sent from my SAMSUNG-SM-G930A using Tapatalk
VernDiesel
Dayton OH
ED
As said stick with half a yard. If you don't have factory air suspension air bags cheap in coil or better axle to frame or tuff truck springs all would work well here. Timbren bump stops work also but for a variety of loads suck by comparison. You can do it without but the truck will wallor over dips etc & you look like a douche.
Bed liner or mat is also smart and if you only have a spray in liner a simple sheet of plywood helps. Smart is to zip two pieces off a sheet to roughly match your tailgate & cab side end so you don't run as much risk to ruin anything like the first poster.
Burla
2010 Hemi Reg Cab 4x4
Every guy who said 1/2 a yard is exactly right. I haul gravel all the time, always 1/2 yard at a time. The most I have hauled in the back was 2000 pounds, that was scary, very wobbly side to side. However, you can get a double axle landscape trailer and haul the hell out of it. A guy came on my property to get some wood last week with a toyo truck hauling a double axle dump trailer with a tow hitch, hauls 5k pounds with ease. You can get a brand new double axle DUMP trailer for about 5 g's, less then you would lose trading in your truck plus you would have a bad ass trailer.
