Cthulhu
- Oct 13, 2011
- 833
- 99
- Calgary, AB
- 2006
- Cummins 5.9
Hey guys/gals/etc..
Got a question, I'm looking for some input on it..
I've got a 19' 4200lb Hideout Travel trailer I tow behind my '06 3500. I've always struggled with what I call wag going down the highway. I've improved the travel lately by some personal training to simply drive the truck and not the trailer but I know its still kicking around back there a bit..
Looking at the tires it seems the outer edge of all 4 tires (2 per side) is wearing significantly faster than the inside. I don't have any pics as I'm in town and its out at a campsite but I'll add pics when I get back in the same spot as it. I'm wondering, should I be rotating the tires? On what frequency? Is the wag causing the wear, or is the wear causing the wag? My father in law has a device on his travel trailer to reduce/eliminate the sway.. its a brake that connects to the outer ball on the WD hitch. Is that a fix for the problem or does that mask a larger issue? My tire pressures are correct and uniform on the trailer.
We've been looking at 5th wheels lately as our 19' is getting a little small with our family now being 4 large... Would I see the issue go away with the 5th wheel?
Thanks for the advice in advance.
