Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Audio & Electronics
Audio & Electronics
1983 w150 with 1993 body and wiring need help.
This is a discussion on 1983 w150 with 1993 body and wiring need help. within the Audio & Electronics forums, part of the 1st Gen : 1981 - 1993 category!
i have a 1983 w150 with 318 carbd someone put a 1993 body on it with the wiring harness cut ...
Reply
Old 05-27-2015, 11:28 PM   #1 (permalink)
Ram Year: 1983
Engine: 318
Default 1983 w150 with 1993 body and wiring need help.
i have a 1983 w150 with 318 carbd someone put a 1993 body on it with the wiring harness cut off with 6 inches of slack and only lights wiper blower harness intact. i need to find all the 1993 wires and then make them work for the 83 motor i only need temp/oil/fuel speedo it has the 83 wires for sending unit but have 93 tank and sending unit. any help would be appreciated.
Sponsored Ad
Register to remove this ad.
Poseidon89 is offline   Reply With Quote
Old 05-28-2015, 09:05 AM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
if you got a 93 tank fuel tank and and sending unit you will most likely also need a fuel pressure regulator installed. also i am pretty sure any 91-93 harness would be about the same for what you need as long as you are keeping it carbed. you could even look at 86-87 harness also since it would be closer to what you would need but you would still most likely need a few 91-93 connectors and sensors to work with the 93's cab harness.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 05-28-2015, 04:31 PM   #3 (permalink)
Ram Year: 1983
Engine: 318
Default
i have a 83 frame motor trans transfer case some one put the 93 cab and tank on before me i have a mech fuel pump on block i have no clue what wires go where there just cut off at the plug in on fire wall all 50 of them. i just need to get my gauges working now the 93 cab is vss speedo the 83 trans is cable i have tail lights headlight turn signals and brake lights wired now i have wired the motorwith push button and toggle switch.
Old 05-28-2015, 04:35 PM   #4 (permalink)
Ram Year: 1983
Engine: 318
Default
what all do i need? i assume be better to just buy a full harness and ecu (for speedo) then use 93 sensord ( oil / water temp ) ill need the speed sensor would it be easier just to re wire from cluster to sending unit or figure out the 5 off the 93 to the 3 from the 83 harnes.
Old 05-28-2015, 04:50 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
a 93's gas tank should have a fuel pump in the tank so i don't think a mechanical pump would be able to pull thru it but i could be wrong. you would also need the connector for the fuel pump and sending unit. as far as the gauge go it would be easier to wire them to the connector under the hood. pretty much all the sensors under the hood have the same resistance's even tho they did change a bit. you can use the 93's speed sensor. you just have to run a single wire the the bulkhead connector and it should make it work. i will see about posting a 93's bulkhead connector diagram in a bit
__________________
Old 05-28-2015, 05:27 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
this should most likely help
__________________
Old 05-28-2015, 09:15 PM   #7 (permalink)
Ram Year: 1983
Engine: 318
Default
Thanks someone removed the in tank and added line so it will pick up that's why the mech pump is there
Old 05-28-2015, 09:34 PM   #8 (permalink)
Ram Year: 1983
Engine: 318
Default
Do the sending unit wires just go to the gauge?
Old 05-28-2015, 09:39 PM   #9 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
ya they just go to the gauge. pretty much everything on these things just go to the gauges. you might have to also ad a ground to the fuel tank sending unit along with the fuel gauge sending unit wire
__________________
Old 05-29-2015, 05:18 PM   #10 (permalink)
Ram Year: 1983
Engine: 318
Default
ok thanks any way you or some one might have fuel sending unit wiring diagram theres 5 wires
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1983 d150 eternity7602 General Discussions 0 03-12-2015 05:14 PM
Re Wiring 1980 W150 with painless wiring kit randocommando Audio & Electronics 3 11-15-2014 08:25 PM
1993 Ram 150 Race Truck Red General Discussions 2 08-02-2014 10:31 PM
Dodge W150 1993 OzzyEatsPeople General Discussions 8 10-03-2013 02:14 AM
1983 Dodge Ram lolorcaust Member Trucks 35 12-07-2011 09:05 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
