87 d150 hard shift into drive
Kemajors
Hi everyone! First time post here
I have an 87 d150 318 with a-904 transmission. My problem is that when I shif into drive it's a bang/hard shift and jump. U joints good, rear end just got rebuilt and is good. Entire truck is stock. All other shifting is smooth. Problem only happens when I shift into drive weather it be from park or from reverse. Thank you in advance for any help!!
crazzywolfie
under the truck
have you checked your motor mounts? i would be mainly inspecting the drivers side one
K
Kemajors
Thanks for the suggestion! Just checked and engine mounts are in good shape
crazzywolfie
under the truck
have you check the fluid level in the transmission with the engine running and the truck in neutral?
K
Kemajors
The transmission was just services for 100k maintenance but I went ahead and checked anyway. Fluid is a nice pink and at the proper level
Goodie1990
