Hesitating
BradshawB
Hello, i have a 1988 dodge w150 power ram. It has a problem with hesitation when accelerated and stalling when stopping. The problem has gotten worse since i got it last year. It now bucks occasionally and will not gain much speed. I have replaced the throttle position sensor, idle control solenoid, fuel filter and the fuel pump. Adjusted the throttle body and the solenoid screw. Also the motor was swapped due to busted seals and high mileage. I'm not sure what the cause of the problem can be, can anyone help?
RotorHead04
MA
By hesitating do you mean misfiring?
Have you checked the condition of your spark plugs and distributor cap and rotor?
B
BradshawB
It doesn't accelerate when i step on the gas, then bucks and goes. I don't hear misfiring.
I have not recently checked the spark plugs, they were new about 9000 miles ago.
RotorHead04
MA
Will the truck stay running if you leave it in park or do you have to keep the throttle open?
B
BradshawB
The truck will stay running when put through the gears and will rev up normally, the issue is when it's moving
RotorHead04
MA
I think it sounds like an ignition issue due to the lack of power. You can do a quick check by unplugging the wires one at a time at the distributor while its idling. If it gets worse plug it back in and move on to the next one. If you unplug one and don't notice a change, then that's your missing cylinder.
B
BradshawB
Okay, thanks for your help. I will try this tomorrow
B
BradshawB
I tried pulling the spark plug wires for cylinders 1&2 and there was no change in the way it ran. Do i need new spark plugs?
RotorHead04
MA
Not necessarily but not you know you have a misfire and where it's at. Pull the spark plugs and examine them. If they are wet then you have a spark problem in either the plug, wire, or distributor. If they are clean and dry then you have an injector issue in that area.
RotorHead04
MA
Do you have a meter? If you do you can see if you have continuity in the wires.
B
BradshawB
I'll check the spark plugs, the wires are fairly new. And i do have a multimeter
RotorHead04
MA
Yea, I'm thinking that it needs a new distributor cap and rotor. He should check the plugs and wires just to be sure.
crazzywolfie
under the truck
distributor cap and wires are most likely fine. with the symptom described i would be looking at the sensor in the distributor. it will cause all the symptoms that are described and is usually only about $30 part and takes about 2 minutes to install
