Big-Pig
I have a 1993 D150 with a 3.9 that wont start. I replaced the in tank pump with a frame mounted pump and now it shows good pressure at the rail, but does not seem to be getting any fuel through the injectors. I also check and i am getting power to the injectors.
1) I dont have a check valve. Do I need one?
2) What else could keep the injectors from working?
Update: I'm getting 50psi at the regulator.
