Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
1990 ram v6 to v8 swap
This is a discussion on 1990 ram v6 to v8 swap within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
Hello I have a 1990 4x4 dodge ram with a 3.9 v6. With a 4 spd manual transmission with a ...
Reply
Old 08-12-2013, 01:58 PM   #1 (permalink)
Ram Year: 1990
Engine: 3.9
Default 1990 ram v6 to v8 swap
Hello I have a 1990 4x4 dodge ram with a 3.9 v6. With a 4 spd manual transmission with a granny gear 1st the v6 has blown up and wanted to see what was involved or needed to swap from v6 to v8. Or if possible thanks for your help
Sponsored Ad
Register to remove this ad.
Ram it! is offline   Reply With Quote
Old 09-23-2013, 11:44 PM   #2 (permalink)
88rambigblock's Avatar
Ram Year: 1985, 1988, 2001
Engine: 1970 coded 440 big block
Default
youre gonna need a v8, a wiring harness, motor mounts, probably a radiator, maybe a fuel pump... the conversion isn't for the lighthearted
88rambigblock is offline   Reply With Quote
Old 09-24-2013, 12:00 PM   #3 (permalink)
Deblackmon3's Avatar
Ram Year: 1990
Engine: LA 318
Default
If you want a 318, I have one for sale haha. It works, but it would be best to rebuild it. I would rebuild it myself, but I don't have the money for it. It also came off of a 1990, so it should wire up without much difficulty.
You'll definitely want a new radiator though. The v8 takes alot more cooling power than yours probably can handle. Do you know how much pressure your cooling system is rated for?
__________________
1990 Dodge Ram D150 S, 5.2 litre LA 318 engine
Deblackmon3 is offline   Reply With Quote
Old 09-24-2013, 12:39 PM   #4 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
radiators are the exact same.
i am not sure about the motor mounts. on the 2wd trucks you need a special motor mount extension plate on the drivers side to stick a v8 where a v6 was. don't know if 4x4 are the same or not. i think you may also want to try finding a v8 wiring harness and computer. it may run with the v6 wiring harness and computer but i think the v8 has an extra sensor on the throttle body that the v6 does not.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 09-24-2013, 02:39 PM   #5 (permalink)
Ram Year: 1990
Engine: LA 318
Default
I just checked up on the sensor count you mentioned. Depending on how old the engine is, Chrysler implemented a custom fuel-injection system for the V8's from '88-'91 and the v6 Dakotas from '87-91. I can't find if the Dakotas were the only ones that received that upgrade or if it also was in the full size pickups as well. If I find any info on it, I'll report back.
__________________
Old 09-24-2013, 02:53 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i know the v8's had some temps sensor on the back of the throttle body that are suppose to help with hot starts that the v6 did not have
__________________
Old 12-02-2013, 03:04 AM   #7 (permalink)
Ram Year: 1990
Engine: 3.9
Default
So will my trans bolt right up to v8
Old 12-02-2013, 02:45 PM   #8 (permalink)
DodgeAddict's Avatar
Ram Year: 1985
Engine: 5.9 Magnum
Default
The computer changes, the wiring can stay,fuel pump stays,the radiator will work(the shroud won't) the mounts will work on a 318 the drivers side changes with a 360 or use spacers to use it
Trans will bolt up with no problem
__________________
I have the CC DD chromosome in my DNA
DodgeAddict is offline   Reply With Quote
Old 12-03-2013, 06:03 AM   #9 (permalink)
Ram Year: 1990
Engine: 3.9
Default
So I won't need the v8 harness. ?
Old 12-03-2013, 06:56 AM   #10 (permalink)
Ram Year: 1990
Engine: 3.9
Default
And also will it matter if I use a newer 318 out of a 95-99 dodge ram ? Or do I need to use a engine from my series ?
Reply
Tags
1st gen motor swap, v6 to v8 swap
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1990 Dodge D150 318 Sputter Jerking Bucking BAD while driving 45mph +...idles great goodoledodge Engine & Performance 10 04-11-2014 12:53 PM
1990 Brake Lights stay on! Gregor Audio & Electronics 3 09-18-2013 11:47 PM
1990 half ton dodge Countrygirl General Discussions 14 06-01-2013 09:28 PM
'93 5.2 swap to '99 5.9 ?? Toon Engine & Performance 3 05-29-2013 03:26 PM
PCM swap Tramotorsports Engine & Performance 0 07-19-2012 09:48 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
