318 lean burn swap?
CoreyD
318 2bbl
Hi all I recently swapped in an electronic ignition kit to replace the Lean Burn computer I double checked all my wiring as per the diagram and went to start it and it attempted to start for a half second then I saw a **** of smoke com from the positive battery terminal and now I have a dead key snd no lights I was wondering what I fried to cause this no power to anything condition?
crazzywolfie
under the truck
best thing to do is test for power at all the fuses. that should help narrow down where your power issue is.
C
CoreyD
318 2bbl
Well that was easy I had a bad splice into the MIF wire
Goodie1990
