Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
OBD plug on my '88 dodge
This is a discussion on OBD plug on my '88 dodge within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
hey everyone, was wondering if any one knows where the OBD plug is on the older trucks?...
Like Tree1Likes
  • 1 Post By crazzywolfie
Reply
Old 06-19-2015, 10:23 AM   #1 (permalink)
Ram Year: 1988
Engine: V6 3.9L
Default OBD plug on my '88 dodge
Sponsored Ad
Register to remove this ad.
kdegans is offline   Reply With Quote
Old 06-19-2015, 10:37 AM   #2 (permalink)
jayhuc's Avatar
Ram Year: 2011
Engine: hemi 5.7
Default
OBD didnt start till like 94 95 ish...
It shouldn't have one.
jayhuc is offline   Reply With Quote
Old 06-24-2015, 01:19 AM   #3 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
the OBD1 plug is under the hood on the drivers side fender towards the corner. it is completely different than an obd 2 and would require a special code reader to pull the code. now you can do the key dance which will do the same thing and allow you to pull the codes.
ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
45 Overdrive solenoid shorted or open (automatic transmission only)
46 Charging system voltage too high
47 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
sbarron likes this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1998 dodge ram 2500 5.9 engine tick after plug wire misfire Zandt85 Engine & Performance 19 10-02-2014 06:34 PM
what plug is right? maladoo Engine & Performance 1 08-11-2014 04:17 PM
plug gap linchpin Engine & Performance 11 04-07-2014 01:23 PM
What is this plug? URdone21 Tech Info 4 07-11-2013 01:14 AM
Bought a Gold Plug! Magnetic oil drain plug. BlkPearlSport11' Engine & Performance 8 12-03-2011 01:55 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
