6.4 and 4.44 gears
SouthernBoy
Central Texas
Anyone heard any feed back on the 6.4 dually trucks with 4.44 gears in back?
I have a 6.4 2500 with the 4.10s and love it, but there is a new cab & chassis 3500 for sale locally but it has the 4.44 gears and Aisin 6-speed auto.
After pulling with my 4.10 gears Id guess that 4.44 would work very well. (of course gas mileage will be atrocious)
Any info is greatly appreciated.
Csanders1992
The difference between 4.10 and 4.44 will be noticeable but just slightly. The biggest difference will be with the transmission
6.4 dude
Oklahoma
6.4 hemi
I have a 4500, 6.4 with 4.44's and the aisin. It's pulls harder out of the gate than my 2500 but at 12k dry weight, it's not nearly as quick. You can feel the torque multipliers are there just the massive weight is holding it up a bit. My tech is getting around 9.5 mpg with the pto running during services and 10.5 out on the highway.
S
SouthernBoy
Central Texas
Thats good info, thanks.
I would put a flat bed on this 3500 if I got it, just doing a little homework first. While my 2500 pulls fine, I think the lower gear would be even better and now that Ive used my 2500 for 2 years I would rather have a flatbed. These newer 4x4s are ridiculously high off the ground and with the stuff I do, it would be easier with a flatbed.
MN-Ram
MN
6.4L Hemi
Are you sure it's a 3500? I didn't know Ram offered a 3500 with 4.44's. Or are they aftermarket gears?
tjfdesmo
AZ
Haven't seen you post in a while, SB. How is that PJ goose doing for you?
RainDesert
ID
Did you get it or drive it?
I would love some behind the wheel time with 4.44 and the 6.4. Comparing my F250 4.30 at 60 mph I'm 1744 rpms, the Ram would be 1644 running same 34.3" tires. I really hope Ram will offer the 4.44 across the board for the 6.4 trucks.
MN-Ram
MN
6.4L Hemi
I'd be happy if Ram offered the Aisin behind the 6.4L with 4:10's. I think that would be a great setup. (In a SRW)
