15BlueStreak
I've said this before but in my opinion the transmission gear ratio thing is way overblown.
If it were not for the Ike Gauntlet video 99% of people would never notice the second gear ratio thing.
Could the ratios be better? yes, would it benefit from an 8 speed yes.
It was one test under specific load, grade, altitude.
In different conditions it may benefit from the steeper 2nd gear.
If the trucks were loaded differently, different grade, altitude, and none of the trucks could hold, or pull it in 3rd, The 6.4 would probably be faster than the Chev. or Ford pulling in 2nd.
If I were planning on pulling at max, in the mountains, I would no doubt have gotten the Cummins.
I completely agree with this. Also this was with an early design model. There recent test of the ram power wagon did not limit the truck at all. Granted I believe it was less weight but they had it
Tached out pretty good and it never limited it's rpm. So I believe the program is different now. I woukd like to see a new test done. The shootout of the big 3 gassers done by pickup trucks.com had the ram winning several tests over ford and gm. That is really the comparison I went on when researching before buying. I am a ford guy but I do go with what is better and in 2015 the ram was the best all around truck I felt at the time and that's what I bought. I do miss the ford truck but this ram checks a lot of boxes for me.
Nathan
