R/T_Fire
- Feb 3, 2015
- 3,432
- 1,205
- Pleasant Grove
- 2011
- Hemi 5.7
Towing rating and payload capacity are two completely different things. payload capacity is truck only based on the axle rating, frame and braking and class of truck. Towing is based on exactly that towing, but you cannot exceed the payload capacity of the axles on the truck, so if you have a bumper pull you cannot max the payload with whatever then add a 1000# tongue weight as it will put you over.
Trailer weight is where your max towing come into, its tongue weight is where the payload capacity comes in and GCVW is your max allowed per DOT and is what dictates the required licensing to pull such a weight in many states
Maybe this will help show the info better. Basically the more your truck weighs the less your trailer can weigh is my point
http://fifthwheelst.com/documents/ram/2015-ram-3500-tow-chart.pdf
