Yeah as far as my motor build, idk i dont think i really plan on going all out. I have built mustang's my whole life and this is my first Mopar build. Well let me tell ya, trying to make this magnum motor put out decent HP numbers is CRAZY exspensive! I guess it's just because the aftermarket world for them never really took off, or maybe it's the power robbing transmissions that we have. It's crazy though how much $$$ it would take to make these trucks put down 400rwhp though. So instead of going all out and draining my wallet for a truck that will never see the drag strip but instead just be a nice weekend cruiser, show truck. I plan on just doing a mild build with bolt-on's
Std rebuild .30-.40 over with 10.7 comp KB pistons
Hughes Whiplash camshaft (curious to see about it with the upped comp ratio)
Comp dual chain timing chain
Ported KEGGER intake
52mm ported throttle body
ford racing 24lb injectors
Pacesetter longtubes
full 3" custom made exhaust with (2) 10series flow's and x-pipe
full A/C delete to clean up the engine bay and free up a tiny bit of hp
MSD ignition upgrade
Would be nice to see 300-320 rwhp on this thing when im done but i'm not getting my hopes up too high.
I have also pondered the thought of doing the 5.7L Hemi swap, MUCHHHH better platform to build a motor off of for HP. All depends on if i can find a good enough deal soon
Last thing while im doing my motor build, i am going to try really hard to find a Manual trans swap. I hear the NV4500 is what i am wanting but they are ball's exspensive and hard to find. I have also heard that the NV3500 will hold up fine as long as i don't plan on going much further into the HP/TQ numbers..........Next fun part is trying to find everything to do the swap, i will need a the 5.9l flywheel, clutch, std pedal assem, hyd setup, t/o bearing, roller bearing AND im guessing driveshaft
