4x4 Gurus step inside
R
RamRoy
Crestview, Florida
edit: found answer to a question I posted....but not the subject of this post.
WilliamS
Tampa FL
Bad news if its the motor for the transfer case getting weak/going bad you gotta pull it out. Good news is the part is about 100 bucks if thats the bad part.
R
RamRoy
Crestview, Florida
Just tried switch at a slow roll and it still would not switch. Any way to test the actuator switch
R
RamRoy
Crestview, Florida
Just talked to my service department. If the actuator switch is bad it is covered under my lifetime powertrain warranty. So, the transfer case is as well. I also have a pinion gear seal that is bad and it is also covered under the powertrain warranty.
I have had my second axle go bad since putting on the low budget tuff-country 4" lift. The angle of the cv axle is ungodly. I am thinking it might be smart to get my 6" lift done before I take it in and then all of the geometry will look accurate and they won't try to give me a hard time
huntergreen
Is your dealer ok with the lift? Thanks
R
RamRoy
Crestview, Florida
They have to be unless they can prove that the lift caused a failure; The Magnuson-Moss Warranty Act. It is not opinion, but proof. Anyway, the guy that did my lift knows they personally and said it is no problem. Good news is that I am having a new 6" lift put on 2 days before my appointment, so as far as they know, the lift was put on after I called them.
