Btw, has anyone even thought to ask the OP if the trip odometer also only shows 6 miles or the actual mileage.
If the cluster only shows what the PCM writes to it then why is it that when you replace the cluster it still shows the donor vehicles mileage??? By what your saying it should change the cluster to match the PCM.... also, if you don't get the mileage reset by a professional then why is it that the PCM continues to keep track of the original mileage while the cluster continues from whatever it was at when swapped????
Also, where are you getting all your info from... do you work at a dealership???
There is a 3 year, 36 thousand mile bumper to bumper warranty. As soon as you sign the papers and drive it off the lot it belongs to you.
There is no return policy, once it has been sold it cannot be resold as a new truck. It would be a used truck at that point.
Dealers do not warranty vehicles the manufacturer does. You can't expect the dealer to take a beating reselling your used truck
I disagree.
a few years back, I bought a reg cab ram. once i got it home, I instantly realized i needed a quad cab instead. So, I went back the next day and was able to return it and get a quad...guess it depends on the dealer/miles put on the vehicle/time etc..
I'm sure it was because you upgraded. It was more money in there pocket
Luke
Luke
There is no ******* match here, sorry for the other who seem to think that. In your question, I think you misunderstood what I said, I said the cluster can write to the PCM. The PCM can, of course, write to the cluster, but it needs to have a signed cert. By what I'm saying is when you change the cluster out, the PCM doesn't know how many miles the car has, that's why it's showing the donor vehicle, to begin with. the PCM doesn't continue to keep track of the mileage on the truck, the PCM only stores the data in RAM, once the power goes off, the PCM no longer knows the actual mileage of the truck, once the power is back on, the cluster can then update the PCM, but the PCM can't update the cluster, not without having a signed CERT.
The PCM does store mileage at intervals, but these are nothing more that data logging, and really can't be used to accurately predict, or determine the mileage of the truck, it's not even encrypted, outside of the blowfish basic encryption they have on the entire PCM. you'd really have to have a pretty good understand of how NVRAM, and RAM function, as well as the encryption board, which is used across almost all of the FCA product line.
Now, OP, I don't really think this was off the initial topic, as we're discussing the way the odometer is stored, and read.
to touch base on how the PCM stores the data again, though, if the truck is started and accessories are in the ON position, RAM has power, ram stores the data from the cluster, it's a temporary save. so like I was saying before, if the data from the cluster is stored in the PCM because it was plugged in ( example ), then the data would not match, and honestly I'm assuming the encryption set would just null the data and trigger a service warning. I'm not as familiar with the workings on the dodge brand as I am with the actual FIAT brand.
My information comes from the 4 years I've worked for FCA. I don't work in a dealer, or as a tech. That's kind of moot, though, you can inquire about how the data is stored through FCA, they will happily explain to you how it gets stored, and where it's stored. They may not go as technical, but they will certainly give you a breakdown.
My initial replies were not saying the truck was dead. I was pointing out that he should merely take advantage of the situation because he has all the power to stand on at the moment with the dealer.
It's also to state that the encryption chipset, will always store the data from the last WRITE, because the data is written from cluster to the PCM, it would likely have it stored. that's the failsafe method used in case both the PCM, and cluster are fried ( say in a flood? ) , THIS chipset uses NVRAM, and stores data even when the power of the truck is turned " OFF ".
As for always being right... i'm NOT always right, as the few hastful comments suggest. In fact, i learn a lot, just like everyone else. However, when I AM correct, it's absolutely imperative that the information being shared is accurate, and correct. All most of you know is if you replace the cluster, the PCM has the mileage.. and that may be true, but it's not the PCM that has the data, it's the chipset that encrypts the datasets from the PCM to the cluster, and vice versa. I'm sorry if I've come off as a **** basket, that's not my intention by any means!
^^^^^THIS^^^^^If the cluster only shows what the PCM writes to it then why is it that when you replace the cluster it still shows the donor vehicles mileage??? By what your saying it should change the cluster to match the PCM.... also, if you don't get the mileage reset by a professional then why is it that the PCM continues to keep track of the original mileage while the cluster continues from whatever it was at when swapped????
^^^^^THIS^^^^^
I know this , if you install a cluster from a diff truck (13-17Ram) the cluster while in your truck will initially read what it was in the other truck , then it will increase in mileage once you start to drive . It will not automatically populate what your trucks PCM has stored .
Just because you didn't get a new truck, doesn't mean he shouldn't. The fact you accepted it with not knowing how many miles were actually on it is quite ignorant actually, sure the dealer told you it was fine, why wouldn't they ?
Anyone that takes a truck that's had past odometer display issues in the past deserves to get screwed, even more so when you're told how imperative it is that it deosnt' get fixed. corrected. No pitch forks, just a good way to stick it to the " man " who constantly sticks it to the people
Thanks manI feel bad for you, seriously
The only people you should feel sorry for are those that don't have the mental capacity to actually read, understand, and retain what's been said. It's a rather short list, but you're on it.
