Recommend Good Replacement Tires
Sportznut
2019 Laramie
Hi Guys
Tried to do a search on this topic but I use Tapatalk and search does not work well.
I have a 2014 Crew Cab 1500 5.7 4WD.
Just looking for a good replacement tire recommendation when the 20" Goodyear OEMs wear out. Sticking with the stock size 20/275/60 or real close to it.
I don't tow or off road, not going to lift or modify. Just want a soft ride for the many HWY miles I log. I do drive in rain quite a bit.
Thanks!
Sent from my SM-N900V using Tapatalk
CherryRed
South West Virginia
Stick with P-Metric rated tires. LT rated tires tend to be heaver and have a higher rolling resistance.
I'll second the suggestion for Michelin.
Jerry1984
Meridian, Idaho
Even though a lot of people don't like the factory tires, if they work well for you they can be had very cheap. Could get barely used take offs for $500 or brand new under $700.
avantiguy
Bay City, Mi
hemi
I like the Michelin LTX but check out the Bridgestone Dueler Alenza plus. They grade out well against the LTX and are $55 or so less expensive.. I haven't run them but if I were buying now I would try them. Very good rolling resistance like the LTX with a high grade on the other attributes.
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
best all around tire Michelins best all around weekend sportsman tire Duratracs
TarPaper
NYC
2016 Sport Black Edition 1500
Hemi V8
I suggest Duratracs...they are great in the snow, great in the rain, look nice and ride well....just my opinion
pcschwenke
Michelin would be great in your situation. I bought BFG ATs KO2 tires since I tow and get a lot of snow in our area. Best thing I've done!
14hemiexpress
Texas
6.4l
I had a set of cooper discovery h/t. Reasonable priced great traction wet, or snow I don't know longevity but I believe the have a good warranty. If i didn't want more aggressive tire I went with cooper discovery atp's I would of went with the H/T's was my favorite tire
Sportznut
Sportznut
2019 Laramie
Thanks everyone!
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
I had Michelin on my first ram and love them.
fordtech90
Jonesboro, La 71251
Firestone destinations are good tires as well. Avg miles are 65k and at 175 a tire, not a bad deal.
Nekozame
In general any Michelin I've put on any of our vehicles over the years have lasted much longer than Firestone or any stock tire. I will be looking into the Michelin tires mentioned above once my stick tires wear.
Gymkata
From what I've heard and read, for your purposes you probably can't do much better than the Michelin LTX M/S2.
