randallwoodward
what he is saying is they appear to be causing a current draw. somethings internal to them they appear to you as "normal" but they are not.
Do you still have the original stock battery? reason i ask is if you do you got many more years out of it than expected. any car battery if you get more then 4 years your on "borrowed" time.
i would do some current draw tests to see how much current is being used then the wipers go on.
No need to do a current draw, as I stated before the solution was change the setting in the Evic and it's all set now. but thank you for clarifying that for me.
