I like the red and black theme. And I say absolutely yes to the rear swaybar. Have you had your truck over 75-80mph yet? Most trucks will get a bad wobble in the rear of the truck at higher speeds with the lowering kit and no rear swaybar.
Hellwig or ADDCO and definitely worth the install of the rear and the upgrade on the front.
When i did my belltech 2/4 drop i noticed i didnt have a rear swaybar? i think one would be nice to tighten things up as far as cornering and stability , who makes a nice one that will bolt right on? , also yea or nay to the mopar Graphics? Thanks
How does a rear sway bar stop a wobble after lowering? (not being a ****, actually curious)
What kind of wobble are y'all getting after dropping these trucks? The only place a wobble should come from is possibly the driveshaft when the ujoint angles change, and the sway bar wouldn't help you there. What am I missing?
I get the death wobble somewhere between 100 and 110. Would love to get this figured out...scares the girlfriend half to death!
