2012 Ram-RCX 2.5 and 295/65/20 Trail Grapplers
FL OffRoad
Vero Beach, FL
Hi guys, new to the forum after I recently picked up my 2012 Ram ST after trading in my Powerstroke. Thought I would share the start of what hopes to be a good build.
Went with the RCX 2.5 to keep the rake.(I think it looks meaner)
Was torn between the Nitto's and the Open Country's for quite a while. Decided to go with the Nitto after seeing so many Toyo's around town. Hope you guys like it. Debating on whether I should plasti dip the rims...:hmm:
fdnj48
Central NJ
Looks good!! You did just the 2.5 level kit? I just did the Bilstein 5100s and now my tires look a little small. Thinking about adding some bigger tires now. Yours are 35s right? Here's mine. dyzanypa.jpgapu4y8uh.jpg
Sent from my SCH-I535 using Tapatalk 2
F
FL OffRoad
Vero Beach, FL
Thanks man! Yeah I went with the RCX since it lifted the back a little too. Yep they are 35s. They fit really nicely with almost no rub what so ever. You definitely need a bigger tire in there to set it off. How do the Bilsteins ride?
fdnj48
Central NJ
Rides like stock!! I think I'm gonna do the same tires as you but I'm afraid of the rubbing.
F
FL OffRoad
Vero Beach, FL
Sweet! Might have to look into those. I've heard the chrome clads do rub with the 35s, being that they are an inch or two wider i believe. A spacer might solve that, but I'm not sure.
quietpeen
2021 TRX
Hellcat
welcome to rf....truck looks good.
35 tires fit with a level on stock wheels........however 12.5" wide tires do not fit on stock wheels without a wheel spacer
pd298
SE Oklahoma
Your truck looks quite similar to how mine looked when I started!
Pugh2012
Will a 275/70R18 nitto trail grappler fit a 2012 dodge ram 1500 with a daystar 2 1/2 inch body lift
Pugh2012
Will 295/70R18 nitto trail grapplers fit my 2012 dodge ram 1500 with a daystar 2 1/2" body lift ?
Goodie1990
