- Apr 28, 2012
- 23,279
- 45,000
- 2010 Hemi Reg Cab 4x4
- Hemi
If you want actual 4x4 function and look to go with that lift, you will want a 17 or 18 wide rim. The taller your tire's sidewall, the more adjust ability you will have on the trail. Competition 4×4’s fitted with bead locks can actually lower psi to 10. With 22's you would need an awful big tire to have any adjustibilty.
Now, if it is a pavement princess, go with the 22's. You will have a ton in common with the low rider pavement princess's as well.
22 versus 17 on a 35 tire, it isn't trail worthy. Lower tire pressures can get you out of many jams, and save your truck on rocks or mud. Of course unless you are gunning it through mud, you should always be going slow with low air.
