Hey guy i currently run the 4 inch superlift. Great lift had it in for about a year. But starting to have a small problem.
Im hearing a rattle noise coming from rear of truck, sounds like my rear springs vibrating when going over certain bumps. (just started) I think its because the rear coils are settled and now are sitting too loose now? I can almost move them with my hands and can repicate noise if i smack the springs, its like a annoying rattle that sounds like a spring.
Im not sure if this is normal, but it sucks because truck was whisper quiet and now i just get mad whenever i hear it.
Is there a fix for this? should i just throw some sand bags in back and see if alittle weight helps? or should i take her in to a shop.
Also truck has crazy rake it looks like stock just 4inches higher everywhere. Bilteins ok to add to this lift kit? and should I get movitechs as well?
thanks for any help
thanks for any help
