Hey guys 15 ram here 1500. 4 inch super lift, everythings been great.
The last month or so ive been noticing a light tapping under my driverside floorboard. Driver side only. Sounds like something is loose. Before i take it to dealership i was wondering what i could look for. Something is definatly loose and causing a vibration through the floorboards. Does not happen on passenger side.
Read up abit on google getting everything from from front frame mount bushing issue because the rubber is too soft. And apparently theres a recall for this i do not know about?
Also any tie rod ends or ball joints. Which i dont think any are bad no reason to be as my lift pretty much retained the geometry in the same way nothings over stressed. Put on maby 20k since install. 40 k on truck
Not sure maby i could get some more suggestions. Its gotten to the point where its ******* me off and its more than just little rattle.
