greychevy
I installed LED switchbacks from the retrofit source(resistors too)in my headlights and when my lights are off and I hit the brakes the driverside switchback comes on solid(the passenger switchback does not). It then goes off when I let off the brake. Also, when I turn on the driverside turn signal, my tag lights flash(again, they do not flash with the passengerside turn signal on)Other than that they function fine. I swapped the switchbacks from side to side, checked the grounds, and checked the electrical connectors....still the same. Anyone have a solution?
