Rzrman328
- Aug 25, 2014
- 5,808
- 3,146
- The treeline
- 2012
- Hemi 5.7
Smoothee, where did you mount yours and how are yours wired up? Post some pics please...
Thanks for the extra pics. That's easy and perfect. I like that you ran those to aux as well so you can light up the world when you want to.Hope you don't mind, OP. Pics aren't the greatest, I can get some more if it ever stops raining. I just bought a pack of cheap galvanized corner braces from Home Depot for about 3 bucks to use as brackets. Depending how they hold up over the winter I may get them powdercoated. They're plenty sturdy for cubes. As for wiring, just used the wiring harness that came with them (had to modify a little) and utilized my factory aux switch panel.
EDIT: DAMN sideways! Pics don't do them justice either, they are really tucked away and still bright as f.
I plan on putting in reverse LEDs on a weekend this month. Cut small squares out of rear bumper (one on each side) and place the LEDs behind bumper for a flush-mount appearance. They should tie in nicely to the back up lights.
I prefer this higher mount to raise the level of the light. Should work great for trailer hook up and to maximize visibility with the back up camera.
Will work on lights up front too
