trmat79
I will start off by saying DO NOT turn down your radio and try to listen for this noise because it will drive you crazy once you hear it. But then again I have done the leg work and found a small but noticable metal on metal noise coming from the right side of my Express so maybe you all should listen for it.
So a few months ago I added the upper glove box to my Express and I love it. So a few weeks ago I start to hear the noise. Well this weekend I pull out the glovebox and find that the small screw (which you have to take the lower glove box out to see) has a metal washer built in so when the truck bounces it can rattle. So what is the fix. Unscrew it, then put a few pieces of electrical tape around the hole from both sides and then poke a hole through the tape and put the screw back in. No more noise. Hope this helps. If anyone needs it I have posted the DIY on the upper glove box instal in the DIY section.
Todd
Todd
