Annoying Rattle Fixed.
trmat79
CA
I will start off by saying DO NOT turn down your radio and try to listen for this noise because it will drive you crazy once you hear it. But then again I have done the leg work and found a small but noticable metal on metal noise coming from the right side of my Express so maybe you all should listen for it.
So a few months ago I added the upper glove box to my Express and I love it. So a few weeks ago I start to hear the noise. Well this weekend I pull out the glovebox and find that the small screw (which you have to take the lower glove box out to see) has a metal washer built in so when the truck bounces it can rattle. So what is the fix. Unscrew it, then put a few pieces of electrical tape around the hole from both sides and then poke a hole through the tape and put the screw back in. No more noise. Hope this helps. If anyone needs it I have posted the DIY on the upper glove box instal in the DIY section.
Todd
1500ram12
5.9L Cummins
Nice. Good to know
Sent from DROID RAZR MAXX using Tapatalk
Power247
High Point, NC
6.4 HEMI
Todd
This is really good info. When I read the title of this thread I was really hoping that you had a solution for the rattle coming from the factory supplied step bar. I have had the dealer look at it twice already. Tightening the bolts does not seem enough to make it stop. It is driving me crazy!!!
trmat79
trmat79
CA
Could it be that it's not actually coming from the step bar?
1500ram12
5.9L Cummins
If it is coming from the step bar get some rubber spacers or grommets and place them in between where you think the rattle is coming from
Power247
High Point, NC
6.4 HEMI
That's what I was thinking. Going to take it off next weekend and see what my options are.
Catchin Zs
Wilmington, NC
Come to think of it, I might have this problem in my 3rd gen. I have a rattle that comes and goes from the right side of my truck, mainly when Im going over bumpy terrain and I have no idea where it's been coming from. This might be the solution
trmat79
trmat79
CA
I'm in the process of hunting down another noise. I'll keep you guys informed
Dale_K
I just joined the forum today and I also have an Express without the upper glovebox. How do you add it? Do you have a link that explains it?
trmat79
trmat79
CA
No problem
09SMOKINHEMI
TEXAS
we're changing your name to "RATTLE HUNTER"..... i'm sure someone could come up with a good pic/sig for your profile :)
thanks for the info bud, I'll be looking to see if I can fix my rattle. mine has to do with the steering column i believe. when I'm driving on the highway, sometimes it'll rattle, but if I push up slightly on the steering wheel it'll stop.... not sure what the heck it is....
trmat79
trmat79
CA
Hmmm thats a good one. Weird though. Maybe something in the steering column itself or possibly just some trim pieces too close??
09SMOKINHEMI
TEXAS
not sure... i don't see any trim pieces that are close
SILVER_BULLET
Mine has a rattle on the console shifter i have to hold it back to make it stop
trmat79
trmat79
CA
See if you can make it make the noise by pushing on the stearing column back and forth lightly. If that is the case then at least you can take it to the stealership and give them an idea of where to start looking
trmat79
trmat79
CA
I would just see if anything is lose first or if there is metal on metal or plastic on plastic contact depending on the noise you are hearing.
