DavidRam
- Feb 19, 2014
- 9,094
- 3,920
- SoCal - Redondo Beach
- 2012 RCSB
- Hemi 5.7
I know a couple of you have seen these already, but I thought they needed a thread of their own if that's ok with you guys!
Materials:
Alcantara - that I had previously ordered from JPM Coachworks
MLV Sheet - mass loaded vinyl, 3/8" that I had sitting around in the garage
3M Fabric Adhesive Spray - also had that in the garage
Dynamat Roller - used for applying sound deadening
3M Double Sided Tape - used the 20lb kind
(Upholstery shops often use a thinner cardboard backed foam for these types of things, but I wanted a beefier look and feel to mine, hence the mlv.)
Cut the general shape out of the mlv, then cleaned it up with a knife and sand paper. Sprayed the adhesive on both sides, let it dry for 10 minutes and then rolled it on with the roller. I am making it sound easy... Getting the corners tight and ripple/wrinkle free is a *****.
Cleaned the door panel off with alcohol and slapped the panels on with 3m 20lb double sided tape. They are on there sooooooo tight I hope I never have to remove them.
Materials:
