Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Interior
Interior
Replacing turn signal stalk/multifunction switch
This is a discussion on Replacing turn signal stalk/multifunction switch within the Interior forums, part of the 4th Gen : 2009 - Present category!
My turn signal switch/stalk is acting up when turning left. It doesn't always return to the middle and I have ...
Reply
Old 12-27-2016, 11:45 AM   #1 (permalink)
OMALLEY_808's Avatar
Ram Year: 2014
Engine: 5.7 Hemi
Default Replacing turn signal stalk/multifunction switch
My turn signal switch/stalk is acting up when turning left. It doesn't always return to the middle and I have to sometime lift it up to help it out.
I took the switch apart and tried greasing the mechanism but even with the stalk out of the truck and in my hand testing, it still sticks so im guessing the plastic just wore out a bit (92k miles).
My truck is out of warranty and it is part #56046114ad which is now superseded by part# 56046114ae
Do these new trucks require re-programming if I end up getting stuck with the superseded part? I know the german vehicles are very picky with stuff like this and I can't do anything on my VW without reprogramming modules.
Also anyone know why it got superseded or if there was an improvement?
Sponsored Ad
Register to remove this ad.
OMALLEY_808 is offline   Reply With Quote
Old 12-27-2016, 03:25 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: I Am Currently Truck Shopping!
Engine: Who Knows?
Default
If the functions of the new part number are same as the old unit, no reflash is necessary.
I have no idea what the changes were.
__________________
MICHAEL
SUPER MODERATOR
MADDOG is online now   Reply With Quote
Old 12-27-2016, 04:43 PM   #3 (permalink)
raff18's Avatar
Ram Year: 2014
Engine: hemi 5.7
Default
changing is super easy
from what i remember its only a 4 wire plus and i don't even think its screwed in
it just pops in and out
i did a 2012 caravan and was surprised at how easy it truly was
can't see trucks being any different as they run off the same system
__________________
flowmaster 50 series HD, cabin filter,
black,2014,bighorn,4x4,5.7,3.92,8spd
raff18 is offline   Reply With Quote
Old 12-27-2016, 05:04 PM   #4 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default
Yeah I already had it out and took it apart to regrease it but still is sticking.
Just the two screws that hold the column cover on, then release the latch, no screws and it pulls straight up.
Old 01-01-2017, 06:26 PM   #5 (permalink)
Birddog's Avatar
Ram Year: 2016 Bright White 3500 Laramie 4X4 Long Bed
Engine: 6.7 Cummins TD, 3.73
Default
Originally Posted by scubabill View Post
92,000 miles on a 2014?! Good God where do you drive?
Seems like a lot of miles but easy to do if you live far from work. I put just over 54k in one year.
__________________
Bak RevolutionX2 Tonneau, Amp Resch Bed Step
Clubs: WhiteTruck#62, 4X4#12, CTD#32, LowMiles#23, AftrDrk#54, Tattoo#38, ChopShop#11, Supporting Mebr#53, RF Hunt, Gun, Military, Motorcycle
Birddog is offline   Reply With Quote
Old 01-06-2017, 12:27 PM   #6 (permalink)
raff18's Avatar
Ram Year: 2014
Engine: hemi 5.7
Default
from what i remember that the switch is released by a nub on the column. if you look at your switch the part that faces inwards. when you flip the switch the nub pops out. if you press on it that should cancel it to the off position. if its working like it should then id be looking at that column.
__________________
Old 01-06-2017, 07:44 PM   #7 (permalink)
Hootbro's Avatar
Ram Year: 2015 2500
Engine: Hemi 6.4
Default
If the last two letters of a part number roll and the front part stays the same, that newer part most times is backwards compatible and is just a in line change for whatever reason that may have corrected a defect or other internal change.
__________________
Hootbro is offline   Reply With Quote
Old 01-06-2017, 08:02 PM   #8 (permalink)
Ram Year: 2013
Engine: 5.7 HEMI
Default
This. It means the part has been superseded, and the new version is considered the correct replacement for any vehicle that used a prior version.
00R/T is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Multifunction switch problem Mason6983 Interior 0 02-15-2016 09:36 PM
04 Ram 1500 Multifunction Switch ilarson007 For Sale 1 09-07-2015 04:26 PM
Custom Switch Back Full LED Turn Signal Retrofit greg214 Exterior 10 06-03-2015 09:43 PM
Turn signal/wiper Control Switch Dug Interior 0 11-16-2013 04:35 PM
multifunction switch going bad? bigtigga84 Interior 4 07-19-2011 01:29 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
