Tablet mount options
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
Hi All :flipthebird:
Hope you are all well, Quick question if I may, anyone suggest or used some sort of tablet mount that permantely attached to the area where one sometimes places there sunglasses?
I am looking at options of installing a 9.7" tablet that can be secured on the dash area ( not windshield suction type ) and figured perhaps there might be something I can buy to drill into the sunglasses area for the tablet to clap to.
cheers
Limeybastard
Limeybastard
Bayou Goat Mounts makes a mount specifically for that area
http://www.bayougoatmounts.com
I dont see anything that holds a tablet there. Plus they all appear to accommodate suction type connections. Cheers anyways.
Sent from my SM-T819Y using Tapatalk
Tyrant
'12CC / '15RCSB
I've got this installed in my '15:
IDKCR01 | by Scosche
they've reduced the price from 50$ to 30$ which i think is a deal if you have an ipad Air... i made a custom backing for my Samsung Tab S2 8.4" to fit but you could also get a Samsung Tab S2 9.7" to fit by just adding a ~1mm spacer to the one side of the tablet.
haven't tested any other tablets so not sure about them.
Limeybastard
Limeybastard
Yeah, its for a Tab s2 9.7" device, I like the location position of that one, albeit blocks the truck display but oh well..
NOcasio7
Tampa Florida
I put mine on the dash on an anti slip pad but a more permanent option would be nice. The tablet I use is only an 8 inch though.
adurm
FL
2015 RCSB
You running that instead of the 8.4?
jcarden10
Raleigh, NC
2014 Big Horn
Limeybastard
Limeybastard
Will the mount plate fit in the cubby or it will you have to mount it behind it up on the dash?
No, I measured the area on the truck where the ram logo is, definitely won't accommodate a 50mm x 55mm base plate for me to drill into using that arkon mount i posted on amazon link earlier.
Jimmy07
Limeybastard
Limeybastard
jcarden10
Raleigh, NC
2014 Big Horn
I saw an image of someone modded a what looks like to be a bayougoat mount with a ball socket. I think if i were to do this then my previous linked item would work.
Bayougoat dont make a ball type mount do they?
https://smile.amazon.com/dp/B00LULUYHC/ref=olp_product_details?_encoding=UTF8&me=View attachment 86789
Don't see any on their website. BUT, the mount you found on Amazon has a hole pattern of 30.17mm x 38.05mm (1 3/16" x 1 1/2"), so it should fit fine on the 2.5" disk on the Bayou Goat mount. Or you could buy the same Ram Ball mount in that picture for $6, RAM 2.5" Round Plate with the AMPs Hole Pattern with B Size 1" Ball Unpackaged - RAM-B-202U | RAM Mounts, although I couldn't find how big the ball is on the amazon mount, so don't know for sure if it would work with the Ram ball mount.
Goodie1990
