- Nov 15, 2016
- 1,026
- 833
- Central Virginia
- 2011 1500 Laramie CC
- 5.7L
I've read some of the older threads on this subject. I want to make sure I'm purchasing the correct fan replacement.
I have a 2011 5.7L with the stock AC efan and clutch fan combo. I'm already running a 180 tstat and custom tune to adjust the fan temps.
I'd like to remove the clutch fan permanently and it looks like the best plug and play upgrade is the TYC 622320 meant for the V6.
https://www.amazon.com/TYC-622320-R...0054RMKZC/ref=cm_cr_arp_d_product_top?ie=UTF8
Can I keep the fan shrouds off after doing this installation? And, did anyone ever end up making a "cap" for the threaded shaft on the water pump after the clutch fan is removed?
Thanks for any replies!!
Nate
Nate
