BlackRamHemi
- Aug 14, 2013
- 1,266
- 557
- Edmonton Alberta Canada
- 2010
- Hemi 5.7L
The front should be the same as the 2013 and lower
Ring & Pinion Sets parts for Dodge Ram 1500 1/2 Ton
4.56 are available. Rear would need to be machined though
Link posted is for 8" (205mm)...not made for 12+ Rams
A Chrysler 8.0" has not been used in a Ram since they switched (front and rear) after 2011 to the ZF axles.
The new ZF front diff (2012+) has 215mm ring gear (~8.5")
and there are no aftermarket non-OEM options that I'm aware of.
