spritee1
had to replace a fuel pump that vwas working intermitant. tipped the bed up and did the replacement.
Now the truck won't start at all. It appears to fire but intermitant. Checked the fuel pressure and read 50 psi. Have only 2 codes 403, 463. the 403 is for the egr which has been there for quite some time. 463 is for the sending unit voltage to high. Do not think that is causing an issue.
Not sure where to go from here??
