- May 11, 2016
- 219
- 338
- North Carolina
- 2017
- 5.7 Hemi
Before performing this mod, I had removed most of the shutter slats without generating a CEL. I removed the entire assembly and inserted the SS deck screw as described by the OP and for a few days of around town driving no issues.
I just returned from a 380 mile trip and also no issues. I did notice that coming up on a traffic slow down on the interstate, even with most of the slats removed, the coolant temp would rise by at least 10 degrees, often more, and slowly drop once under way again. (I'm running a 180 degree T-stat) With the assembly out entirely, the coolant temps did not rise in a slow down situation as dramatically, and dropped faster once underway again.
I've also read that the shutters tend to remain closed, even while steady-state cruising with minimal throttle input, and open (at the slow rate of the dc motor) when accelerating. They close again with light cruising throttle. They may open if coolant temps get really high (as in above 220 F degrees , but I've not been able to confirm that.
In any event, the assembly will remain out until and unless a CEL is generated, as giving the radiator, AC condenser and trans cooler full access to pressurized air flow while underway has to be better than periodically blocking that flow.
Finally, I've seen zero fuel usage increase with the assembly removed in highway cruise conditions. In fact on this last trip, with the assembly removed, and with MDS turned off, I saw the highest hand calculated fuel mileage ever, 22.8 mpg; and that was while cruising between 70 and 75 mph.
