Good research guys, i like the idea of the black magic fan, so I went looking too, I found this....
https://www.summitracing.com/parts/...jzdKvu3dRW8J5YdJfkuBcK6w3R8WYSHBoCfLwQAvD_BwE
I haven't measured, do we have the real-estate to install this monster with a fan controller, or maybe tie it into the existing wiring. this would be removing the existing AC fan as well going back to that plug and play Moe was talking about.
Crazykid, I get what you are saying, but the problem is that your test was done at 75 degrees outside. Add 40 degrees to that outside temp and you our highs in Phoenix and Vegas. I have to travel the highway from Tahoe to Phoenix at least once monthly every month of the year, summer maybe 2x. If you add 40 degrees to the outside temp, all those numbers go up- not the same amount, but there is some increment.
I like the idea of the shutter removal- we are getting very close on a solution! Like baking a cake right! Little bit of this, little bit of that, lol.
