Curlyp
That Redline/RP filter club is sure filling up quick these days.
Burla, do you know what ramnewbie is talking about in regards to the pressure relief?
Just like sheep
Yeah, you're probably right, but with base end relief valve I have no tic, dome end, tic.
No, my 2 filters that ticked were Purolator boss and FU. Went back to Mopar filter and no tic. This is me but I would never run an oil filter that long anyway, 6 months, 5 to 6 thousand miles.You had a RP/Amsoil filter and it ticked? I tried Puro synthetic filters, I actually bought two, and my truck had a tic with them, but not the RP that I had prior, so I went back to RP. I know there are a few synthetic media filters to choose from, the spun micro glass has me sold for life. If you know of one that has a different valve, that would be good info for someone to consider. I only know my experience, I have a puro synthetic that fits my ram I will never use unless maybe I do a flush someday. Not likely with redline, but if I ever see clumps in my oil I would do a flush.
I understand where you're coming from, just saying I would never run my oil that long, just me. Years ago when I was running Amsoil SS I would change it out at 10,000 miles because it just looked really dirty, and that was with their EA filter. At that time it only took me about 3 months to put on 10,000 miles. I had that Dakota 2 1/2 years and had 84000 miles on it when I traded it in. Dealer ask me if I rolled speedometer back and I told him if I had I would have rolled it back a hell of a lot further than that. Anyway, now, I drive a lot less miles and 6 months, 5 to 6 thousand miles is an OCI that I'm comfortable with. Even if I was to switch to redline, not saying it's never gonna happen, just not there yet, I would still go with my current OCI.This is the reason why I choose RP filters, I didn't put much thought into the bypass valving or drain back valve, my main concentration was to find a high flow synthetic filter first and foremost. I like the idea of FU, I just bought a case for the wife's SUV which is a canister, but there is conflicting info if it is 100% synthetic, or combo. So I have seen a few wix xp/napa platinum, to me they are thinner tighter pleats, whereas RP is thicker maybe looser pleats. The micron rating between the two favors Wix XP by 5 microns (however there have been issues if you read Bob's), but that means the flow would likely benefit RP as far as the media goes, and also the holes are very generous as well, probably why it doesn't tick at all but with the puro boss it did. Of note, puro yellow can I had no tic for whatever that's worth.
Normally I am not this **** about it, but when you have a truck that is finicky and knocked like an old engine on it's last legs but yet is new, you search and try and if you can smooth out the ticks why the hell not? If I was on a 5 month interval I might consider paper, but I'm not changing the redline that early. My two year OCI still had 3 tbn left, I wanted a filter that could match my oil, and I found it.
When it comes to synthetic filters, there just aren't that many options. With these hemi's I think going back to paper filters and a 3 month OCI is not a bad play at all, but I got rid of my tick with redline as many guys have, here and at bob's, so I'm kinda in a box. I found what works for me.
Burla are you running the small oil filter or the big one ? If so can you pleasegive me the stock no. Thanks
I get mine off Amazon, the parent company has went bankrupt, I'd buy 6 if you can. This is the large size will fit.
This is technically your model, 10-48, but the guys are running the 20-820 as it's bigger, either way.
yesburla thanks for the reply i been running the big filter mine is a 2012 so the no.will be the 20-820 correct?
Is that pressure relief valve on dome end? I think OE Mopar filters are base end. I know that the RP filter is highly regarded on here but I feel safer with a base end relief valve if that's what Mopar says they should have. Jus sayin.
Maybe that's what's wrong with us, we're all ALPHA'sThats what I have been saying, I will change my oil once a year and only deal with the crappy filter location once a year for about the same price .
Bonus I get to use a oil and fliter that is known to stop the tick.
Its not being sheep to use a good product, and if we are sheep then we are all because we are all driving Rams.....
