I sent an email to Lucas to find out if it OK to use Lucas Synthic Oil Stablizer in my 6.4L - No
"Thank you for contacting us.. Do you know if your truck comes with a MDS system?(engine-cylinder deactivation system.
if it does come with this system.. we do not recommend you add anything ..
thank you"
Next Question - Is Lucas Fuel Additive OK.
"Yes, the fuel treatment is ok to use in there if you are just using regular fuel... but no oil additives... because the MDS system works of the oil viscosity..I dont recommend you use any additives. "
thank you"
