Norton: I am not to familiar with the 4.7L but after looking a few things up...
For the oil filters you have on hand-->Use the FL-820S for your normal 5K-8K mile OCI... {Great Filter}... it cross references with the Mopar MO-899...
Depending how **** you are? There are 3 more robust and efficient filters too choice out there-->{Synthetic Media}... Royal Purple & the Fram Ultra XG2 or Mobil 1 MO-210... Mind You-->This all depends how **** you are about your 4.7L and Oil Changes...
Now you will get thousands of opinions and thoughts and advice on your Oil Brand and Viscosity... I did some reading on this motor... There are alot of comments about this motor having sludge issues... There are so many this issue is tough to ignore... I personally would keep my OCI around the 5K mark { I personally would not go past 5K miles on your OCI}...
You never said anything about your oil brand choice {which might be a good thing}! I personally would use 5W-30 or 0W-30... Many comments I read state this engine is not quiet by no means so a thicker viscosity oil just might help quiet some of the noise... I might being just me use a 10W-30! I just poured in PP 10W-30 in my wifes & daughters 2012 Ford Edges and really quieted down the 3.5L in both... Really Impressive...{Both Call for 5W-20}... Wife just arrived back from a 421 mile round trip averaged 27 mpg with the 10W-30...
I would chose an oil that has a higher then average detergent package and keep my OCI at least around the 5K mile range...
This is a great place to familiarize yourself with what exactly is within todays oil brands...
http://www.pqiamerica.com/
If you only use conventional oils-->Check into PYB 5W-30... If you chose the 30wt version... Great Cleaning Additive Package + an A$$ load of Moly!! Even the 5W-20 version would be a great choice if you chose to stay with the 20Wt version... Quaker State is a sister oil of the PYB and also has great cleaning abilities as well as a healthy dose of Moly!
I do apologize if I posted more info then you wanted... Once I get going-->I am a Rambling Mess! BUT-->Once again ALL of This is Only MY Humble Honest Opinions! Nothing More...
Since I posted prepare for all kinds of others posting and contradicting & ridiculing my opinions and thoughts... I do apologize again...
