OK.. got this ordered in from Moe's (and they are awesome guys.. no complaints there!)... and went to do the install today on my 2013 ram 2500 power wagon 5.7.
First several steps went fine... then things started to go to crap.
There are A LOT OF ISSUES with the parts that came out of the S&B Cold air intake kit box... Parts that do not appear to be able to in any way fit together. I am hoping/assuming that this was all just a big mix up from their factory, and S&B (via Moe's? haven't called them yet.. waiting til monday) will send me a new, CORRECT kit where all the pieces fit.
Case in point.. in the following pics, you can see that the clear plastic cover does not fit the top. If you line up the hole near the front edge, fender side, the rear hole cannot be aligned.
ALSO> the screws are the wrong size! Directions say 1/4x20 phillips head screws with rubber washers... see pics! Back holes? TOO SMALL... front holes TOO BIG! The screw kit that came in the box is too large for the rear holes.. but will slide in and out of the front holes...
See next post for more!
