Ethanol only harms fuel systems when they sit. If you use it in whatever concentration, it will be fine as long as you constantly use it. The problems come in while storing. The alcohol in Ethanol fuels attract water- very quickly. As long as you keep using it, it burns up without issue. When it sits, it accumulates water and the water separates and sits on the metal, then quickly corrodes it.
Flex fuel vehicles have fuel system components comprised of plastic and metals with corrosion-resistant coatings.
Case in point: My Hayabusa tank is now a wall ornament because it sat for 9 months with ethanol in it while I was TDY in Germany. I had treated it, but my brother drove it and refilled the tank without treating it. When I got back, I went for a short ride. I felt something cold on my leg. It was fuel dripping from the underside of the tank. I slid my finger up under there to see where it was coming from and my finger went right through the bottom of the tank. A few gallons of fuel came gushing out. Fk ethanol!!
Sent from my Samsung Galaxy S8 using Tapatalk
